If you want to see the contours in your maps, running Garmin BaseCamp with the watch plugged in to the PC will allow you to use the built-in or downloaded maps on the watch. (BaseCamp is an oldie but a goodie. Google it and you'll find out how to get it. I think it is MUCH better than the cloud-connected stuff.)
Glad I could help.
BTW, you can download maps to your watch. I did so very successfully when travelling to the UK and there is a great site from which to get good maps for there. https://talkytoaster.me.uk/
Also, the alarmingly named but very good 'ShonkyMaps' from http://shonkylogic.net/shonkymaps/ are great for Australia.
Others are available from other places. Many are free. Be careful of the size, though the F5X has a generously sized 'disk' I think people are running into issues with upgrading maps because of sizes.
To install such '3rd party' maps, unzip the download (or whatever) and put the gmapsupp.img (or whatever the .img file is called) map in the Garmin folder on the watch. (plug it into the PC and it should appear like another drive) You can rename it, keeping the .img extension and you will need to do so if you have more than one.
To select which one(s) are 'on', you need to display a map using an activity, then hold 'menu button' then scroll down to 'map settings' ->'configure', -> 'map' and choose the ones you want. Not sure of the value of having more than one selected and not sure which one gets displayed if you do. Note that some are 'routable' and some are not.
Another good trick is to put the maps on a USB stick in a top-level directory called Garmin. BaseCamp detects it and thinks it's a device and allows you to 'use' the map without your watch plugged in.
Terry
I'm not seeing how you import, say, a run route you recently did.
