Time zones
Does anybody know how to change the time zone of the watch?
I travel a lot and have to change the time frequently. The two options i get to change the time are:
-manually enter the new time, or
- sync with GPS.
I do not see an option to change the time zone.
I think this is fundamental option for a watch but I cannot find it.
  • I am not travelling so much, so have such huge experience with this topic, but sync with gps would be sufficient and fastest/most precise way how to change time (zone too). If I need to use it often, would assing it to a button and then after getting out of plain or in taxi would push the button, done.
    Somehow I resist to enter manually time or time zone, but this is just my view on that. Even when hiking and calibrating altimeter at some point where I can see that I have incorrect elevetation, always give chance to GPS first and then calibrating manualy.even if I see the real elevation.
  • Sveta and did you try some watch faces offering another time zones time? That may be a solution for you as well.
  • The watch should update automatically, but it needs to know where you are. So when you get off the plane, save your location.
    Well, the sync using a GPS could be very difficult: I get off the plane and then immediately go inside the airport- no open sky.
    Manual sync is giving always some inaccuracies in the range between + 59 seconds and -59 seconds, depending on when you started setting the time.
    And last but no least: I work on board a vessel- we change time zones very often and we are not considering the actual time zones we are in, so I cannot rely on a GPS sync.
