How to upgrade from beta to public release?
I'm currently on beta 10.55 and would like to upgrade to the public release 11.00 once it's 100% rolled out. Is that an option that will show up automatically on my watch or in Garmin express or do I need to take some other action? I'd like to avoid losing all my settings if possible but the only info I found said if you roll back to an older release things will be reset. Any help on this? Thanks
  • He is asking to update from 10.55 to 11.00 - so NO downgrade! And so also NO risk to loose any setting.
    @%Garvmin%
    If you have set up your F5 for automatic update - no action needed - will updated in the next day(s). If youre in "hurry" - try to connect to a PC and run GE - probably the updated will run immediately. And again - due it's an updated - no setting will change.
    Sure - i didn't recognise he's at beta 10.55 - thought he's at beta 11...
    Sorry for that.
    And in this case (when at beta 11) he has to do a downgrade, because when using a beta its only possible to upgrade to a final one if the final one is a higher version - otherwise you must downgrade before...
    "Last edited by SUSSAMB; 10-10-2018, 01:23 PM. Reason: Language" is written in your post - didn't know why... but i can imagine what the reason was - in this case - your name will be program.
