Bluetooth: Pairing doesn´t work anymore after firmware-downgrade
Hi.
Because of a big problem with firmware 10 (counting swim-laps) I installed 9.20 again. But now I can´t pair my Sony Xperia Z with Garmin Connect anymore (It worked until I changed firmware!).
After update to 10 again (for test) it also doesn´t work. So it should not be a problem because of changing firmware. It still works with another phone (Samsung S6; I used it only for testing and erased pairing after test).
I tried every workaround I could find: https://support.garmin.com/de-DE/?fa...bt83UTDHqYJZG8 ; Bluetooth-Reset on Xperia Z ...
Nothing helps.
When I start pairing with the app there comes the field where I have to enter the code which is shown on fenix5. But the code is shown only for 1-2 seconds and before I can enter it on the phone the watch shows the error message "Kopplung fehlgeschlagen" (pairing failed). When I nevertheless enter the code after showing this message: message in Garmin Connect = Fehler / Wiederholen (failed / try again).
Pairing with Xperia-Bluetooth (without GC) works (I´ve tried it only for testing and erased it after test). But I have to pair it with GC.
Do you have any idea? Garmin Support has no more idea ...:(
