Help, Fénix 5s
Hello
I have been using a 5S
no problem with it
everything is fine with me
but for a week it's been impossible to recognize her on my PC!!!!
I didn't change anything but when I connect it I get the following message;
impossible to open disk F, it must be reformatted
I don't want to reformat it.
I don't want to have to recreate my profiles by activities
is there a solution?
sav Garmin asks me to return the watch
I'm starting a pre-marathon, so not too hot.
thanks to you if a trick exists
Translated with www.DeepL.com/Translator
    Heya,
    I have exactly the same problem with my F5,
    I think it came with update to 9.20, after then F5 is not seen by PC,
    It showed message in win10 multiple times that USB device is not recognized.. After few tries it even stopped showing the message...
    F5 are being charged tho.... I thought it might by cable since I tried it on multiple PCs... So I picked up a new one today...
    It doesn't work either....
    F5 were updated to 10.00 through garmin connect... I was thinking it might fix it, but nothing...
    I can't even force F5 to USB mode... I tried reseting it to stock.. nothing...
    Interesting... but it worked flawlessly until then...
    Some solution would be cool.
    Thank you!
    BR,
    Pavel Z.
