Maps
Anyway to delete maps from the 5X I'm not using? But be able to put them back when needed.
    I have deleted map from the watch and reinstall from garmin Express later.
    This is not officially supported from garmin support in my country.
    Hope garmin can confirm that reinstall maps is something that is supported, and will be in the future.
    best regard
    I do that all the time:
    - Install maps from Velomap.org to Basecamp
    - Copy using Garmin Mapinstall to the watch, while removing maps not needed for the moment.
    Sort of a topic drift, but how does one replace the default route maps that comes with the Fenix 5X? Mine was a gift that was apparently sourced from the UK, because while it has highly detailed European maps installed, the North American maps appear to be simple base maps, not detailed route maps.
  • You need to buy North American maps from Garmin. Or you can use free OpenStreetMaps maps from garmin.openstreetmap.nl or garmin.opentopomap.org.
  • My question is how to determine which file is which region? All of my map file names are like this ‘D6019000A.img'
  • Try GMapTool: http://www.gmaptool.eu/en/content/gmaptool
    gmapcycle.img 3872587776 2018.5.28 6:52.8
    F: PID 1, FID 7648, Garmin Cycle Map EU, North East, 2018.10
    D6019000A.img 3425959936 2018.5.28 6:50.50
    F: PID 1, FID 7648, Garmin Cycle Map EU, South West, 2018.10
    gmapprom.img 3598057472 2018.2.7 8:0.12
    F: PID 1, FID 7031, TopoActive Europe v4 West
    gmapprom1.img 2467823616 2018.2.7 7:43.26
    F: PID 1, FID 7032, TopoActive Europe v4 East
    D4713060C.img 963657728 2018.5.28 6:48.46
    F: PID 1, FID 7476, Garmin DEM Map EU
    gmapsup1.img 28989440 2018.4.12 11:31.14
    CourseView Medium SE Americas
    gmapsup2.img 14764032 2018.4.12 11:31.36
    CourseView Medium SE Europe, Middle East & Africa
    gmapsup3.img 13682688 2018.4.12 11:31.28
    CourseView Medium SE Pacific
    gmapbmap.img 51003392 2011.3.14 7:43.32
    Worldwide Autoroute DEM Basemap,NR
    gmaptz.img 587776 2017.12.29 5:29.14
    Time Zone Map
  • Thanks, pprimoz.
    It seems that GMapTool is Windows only, unless you use a command line version in MacOS, but I’m not sure how to do that.
    Can I just delete those images from the Garmin folder?
    Where do I go to re-download them again — is it just in Garmin Express?
  • Don't delete them , move them somewhere safe and just copy them back when needed
    And do not forget to move (backup!) also files with extensions: GMA, SUM & UNL !!!
    In fact, it would be wise for each owner to backup whole directory structure with all the files (even hidden ones!) and especially the following (maps related) files:
    D4713060C.gma
    D4713060C.img
    D4713060C.unl
    D6019000A.gma
    D6019000A.img
    D6019000A.unl
    gmapbmap.img
    gmapcycle.gma
    gmapcycle.img
    gmapcycle.sum
    gmapcycle.unl
    gmapprom.gma
    gmapprom.img
    gmapprom.sum
    gmapprom.unl
    gmapprom1.gma
    gmapprom1.img
    gmapprom1.sum
    gmapprom1.unl
    gmapsup1.gma
    gmapsup1.img
    gmapsup1.sum
    gmapsup1.unl
    gmapsup2.gma
    gmapsup2.img
    gmapsup2.sum
    gmapsup2.unl
    gmapsup3.gma
    gmapsup3.img
    gmapsup3.sum
    gmapsup3.unl
    gmaptz.img
    gmaptz.sum
