Fenix 5X - 9.71 Beta Release
Hello Fenix 5X users,
We have new beta software ready for your upcoming adventures!
Fenix 5X: https://www8.garmin.com/support/download_details.jsp?id=11665
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
9.71 Change Log Notes: Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fenix 5 series you have in the subject line.
  • Added support for Connect IQ SDK v3.0.
  • Improved a case in v9.53 that could have caused battery drain for the Fenix 5X
Please note, the beta updates released on these forums are not suitable for APAC region devices.
  • I think I have found an issue.
    The caching of of location for next sun event calculation on my watch face (Europilot series) has stopped working. I check this against a couple other watch faces and the next sun event calculations are not working, which I suspect is due to writing/reading/caching location values from the watch storage.
    This is probably due to the upgrade to new firmware and the longitude and latitude that the watch face needs for the sunrise/ sunset calculations being lost. Simply open up a running activity and keep that open until the watch gets a GPS location. Then discard the activity and go back to the watch face. It should then have the correct lat/lon to do calculations. Thanks
  • This is probably due to the upgrade to new firmware and the longitude and latitude that the watch face needs for the sunrise/ sunset calculations being lost. Simply open up a running activity and keep that open until the watch gets a GPS location. Then discard the activity and go back to the watch face. It should then have the correct lat/lon to do calculations. Thanks
    I'm aware of this and the sunrise/sunset is not working despite having a lat/longlong and having completed a few activities. It is also not working for a few different watch faces, including Europilot, which I wrote.
    When I get back from vacation, I will have to fire up my dev machine and see what's actually happening.
    Is anyone else swing a similar issue?
  • Not sure if anyone has gotten word from the Garmin people, but I just received this via email. Figured I would post it and have y'all give it a go and see if you see different results. I'll try this as soon as I get home.
    Let us know if you get different elevation readings with the below recommendations.
    [h=3]Understanding How These Sensors Work[/h]
    The barometric altimeter on the fenix Chronos and fenix 5 series use barometric pressure to determine changes in elevation, as well as pressure changes caused by weather patterns. Taking advantage of the fact that weather pressure changes occur at a slower rate than a person going up or down a hill, the unit will automatically transition between two modes; Altimeter or Barometer.
    • Altimeter mode locks the barometer value and assumes all pressure changes are due to elevation change
    • Barometer mode locks the altimeter value and assumes all pressure changes are due to weather
    These wearable devices continually monitor barometric pressure to determine which of these modes is most appropriate at any given time. When the rate of change in pressure is significant, it indicates movement and therefore the changes in pressure indicate elevation change. The watch will go into the altimeter mode allowing the altitude to change and locking the barometric pressure.
    When the rate of change in pressure is not significant, it indicates no movement and therefore pressure changes are due to weather. The watch will go into the barometer mode allowing the pressure reading to change and locking the altitude.
    [h=3]Manually Selecting a Mode[/h]
    It is possible to manually lock the watch into the Altimeter mode if your activity involves changes in elevation or lock it into the Barometer mode if your activity is in a relatively flat area. The Barometer mode is also useful if you are more interested in your watch notifying you of impending weather changes instead of elevation changes.
    [h=3]Barometer Settings[/h]
    I've got the same mail from garmin. nothing helped here. even tried to switch from smart mode to 1sec intervals. In my opinion this must be a SW Bug. Something with the grade recognition is slow. since the official 9.2 fw rollout i think i got problem with stair flight recognition too. maybe this plays together...
