+1 Here. I am going to do a soft reset. I have not added any new watch faces since the update. I am hopeful another software update will resolve this, or if someone else has a suggestion that will remedy the battery drain as I would usually only have to charge my fenix 5x once a week or so. Currently it is every three days now. I look forward to hearing other suggestions than soft reset or watch face removal.
I've noticed it's losing around 25%/day, just started recently, also with sw9.20 Also when I press an up/down button to look at a widget, it takes a measurable amount of time to change, it used to be instant, which makes me wonder what the watch is so busy with that the request takes time to carry out.
+1, same use as before, now I need to charge it 40-30% earlier. So battery life is reduced to 70% I also noticed that on the stock watchface the seconds hand skips some seconds, about every third/forth one. The restart of the watch helped (but not with battery life)
Same battery life here also (Fenix 5 Saphire edition) , using MoveIQ, sleep tracking and 24/7 heart rate. I run 3 times a week and go on 1-2 bike rides, all in all around 6-7h being active, i have no problem going trough the week. I charge mine on mondays and it's rarely under 20% when i do.
