Fenix 5S/5 - 9.53 Beta Release
Hello Fenix 5S/5 users,
We have new beta software ready for your upcoming adventures!
Fenix 5S: http://www8.garmin.com/support/downl...s.jsp?id=11661
Fenix 5: http://www8.garmin.com/support/downl...s.jsp?id=11663
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
9.53 Change Log Notes:
  • Added GPS + GALILEO support (Activity Settings > GPS). (Requires GPS version 2.20)
  • Added abnormal heart rate alerts. Enable these in Heart Rate widget > Heart Rate options > Abnormal HR alert. An abnormal heart rate will be detected if your heart rate exceeds the entered threshold for an extended period of time while sedentary.
  • Fixed a bug causing Cadence values to be 'stuck' when not pedaling instead of returning to 0.
  • Fixed a crash seen when viewing SwimRun activities.
  • Fixed a crash sometimes encountered when selecting apps.
  • Fixed a bug causing some activities performed on multiple devices to be double-counted when viewing Training Load on Physio TrueUp devices.
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fenix 5 series you have in the subject line.
Please note, the beta updates released on these forums are not suitable for APAC region devices.
  • Am I right that you can only have GPS+GLONASS or GPS+Galileo, there's no option for all three?
    So far I guess not, the plus watches also only can have 2 at the same time. I'm wondering if a GLONASS+Galileo option would make sense, if the watch can only handle 2 at the same time.
  • Could you please she some test ,compare new configuration gps+ glonnas Vs gps + Galileo.
    it is big differences?
  • I'm a F5 users since a couple of weeks, coming from a VAHR, and upgraded to this beta without issues. This morning I had a 50km MTB ride with lots of curvy single tracks and 90% under trees, so a good test case I think. My F5 was on GPS+Galileo and took my Oregon 600 as well with me with GPS+Glonass. At the end the F5 showed 50,0 km with recorded 8584 points and O600 showed 47,1 km with 2445 points. I compared the 2 tracks on the map in basecamp and the track from F5 followed the paths on the map way much better then the O600. So far no complaints from me regarding GPS accuracy. Next time I will compare the GPS and GPS+Glonass for the same route again.
    In the 2:40 h ride the battery dropped from 57% to 40%, but that is including speed, cadence and HR sensors as well.
  • not saying that this is necessarily beta related, but i would like to ask if someone else noticed something like this as well.
    i installed the beta late in the evening and the next morning the training load had dropped significantly. i did not train less in time, distance and intensity - i would say i did train a little harder than the weeks before - but the training load dropped from 380 to 140. maybe this is just some special calculation from firstbeat...?
    My TL has decreased but my load has decreased, in a way that seems believable. May take a week to see if it seems right
  • Is it just me or the HR reading is a little unstable with this beta release? It fluctuates more than with the 9.20 and goes a little higher than usual. I' ve installed it just a couple of hours ago, but I'm starting to regret doing it.
    Not here. Not noticed any change to HR
    Hr is fine here, too.
    Lactate threshold is still not updating and stucked at an not possible value of 46 (it says that it was entered manually but it was not).
  • What about the ability to ONLY choose Galileo ???
    Only Galileo would be good to see how it works. He proposes to add them in some beta version in order to check and listen to the opinion of beta testers.
