No drills in swim guided workout
on 7.60 - but intervals defined as drills in Swim Workouts are not recognized as drills on the watch. If you then not move the arm, they result as 0 distance and Rest Interval, which is not correct.
btw, is anyone able to fix the fit file (to change to change every second rest interval to swim?
    Did you use the mobile app or a PC/Mac and Garmin Express to send the workout to the watch? I've had this problem too, on 7.60 and on earlier firmware, that if I send a swim workout to the watch from the mobile app it doesn't recognize drills correctly, but if I use my computer and Garmin Express it does. My guess is there's some kind of bug in how the mobile app sends the workout to the watch so if you're using the mobile app maybe try using Garmin Express and the USB cable and see if that works.
  • yes, I used the mobile app. Need to try then with computer...
