Fenix 5X - 7.91 Public Beta
Hello Fenix 5X users,
We have new beta software ready for your upcoming adventures!
Fenix 5X: http://www8.garmin.com/support/downl...s.jsp?id=11665
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
7.91 Change Log Notes:
  • Added support for a Sunrise & Sunset widget. Settings > Widgets > Add Widgets > Sunrise & Sunset.
  • Added support for an Alternate Time Zones Widget. Settings > Widgets > Add Widgets > Alt. time Zones.
  • Added a setting to display a calibration prompt when using a power meter. When using a Vector, this will also allow the user to set the power meter crank length. Menu > Settings > Sensors & Accessories > Power Meter > Calibration Prompt.
  • Fixed an issue where the altitude on device wasn't accurate when using the Jumpmaster app.
  • Fixed an issue where Broadcasting Heart Rate was not working as expected, if accessed from the power controls menu.
  • Fixed an issue where a ConnectIQ watchface would flash when downloaded using the Garmin Connect Mobile app and the device would revert back to a stock watchface.
  • Fixed an issue where Flashlight would turn off when using gestures.
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fenix 5 series you have in the subject line.
Please note that the public beta's are intended for non-APAC devices only.
