Just setup a milestone footpod with my Fenix 5 sapphire. Under the sensor settings I am wondering if it's best to either;
disable auto-calibration: then manually adjust -/+100 value to match the treadmill pace/distance (hopefully it's correct), or;
enable auto-calibration: go for a few runs outside and hope my GPS signal is good enough throughout (which is half the reason I bought the pod in the first place)
alternatively I disable auto cal, run outside and use my phone GPS for distance - again need to hope the signal stays strong.
Any advice on the best approach? Will likely use my FP for both pace and distance as my F5 has regularly been 200-400m off total distance in the past and pace off as well, thanks to some towering trees here.
I haven't and probably won't (unless needed) be using the Milestone app.
Thanks in advance
