Fenix 5S/5 - 7.54 Public Beta
Hello Fenix 5S/5 users,
We have new beta software ready for your upcoming adventures!
Fenix 5S: http://www8.garmin.com/support/downl...s.jsp?id=11661
Fenix 5: http://www8.garmin.com/support/downl...s.jsp?id=11663
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
7.54 Change Log Notes:
  • Added the ability to access 'Broadcast Heart Rate' from the Controls menu (Settings > Controls) as well as through the system Hot keys (Settings > System > Hot Keys).
  • Improved the smart notification text layout for longer messages.
  • Improved manual weight entry for Rep Counting. When entering the weight for a set, the default value will be the weight entered for the previous set instead of 0.
  • Improved the VO2 Max gauge in the Performance widget so that the arrow indicator is more accurate.
  • Improved syncing of user settings and statistics between the device and Garmin Connect. Addresses issues like alarms being changed unexpectedly.
  • Fixed an issue causing the Lactate Threshold page in the Performance widget to not show if an auto-detected BPM value is the same as one that was manually entered.
  • Fixed an issue where the entered angle field would change its contents to a bad value within Jumpmaster.
  • Fixed an issue where the scrollbar would disappear momentarily when adding a chart page (for example altimeter) to the activity data field page loop.
  • Fixed an issue where the data field 'Gear Battery' showed no value on the Varia Vision.
  • Fixed an issue where laps were not being recorded correctly while performing a lactate threshold test.
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fenix 5 series you have in the subject line.
Please note that the public beta's are intended for non-APAC devices only.
    Hello!
    My 5S is still on 7.54 BETA software.
    I have an LG G6 phone.
    Yesterday I set a wake up alarm on the 5S for this morning and afterwards synced the 5S with the Garmin Connect Mobile app on the phone. Then I went to bed.
    This morning both the watch and the phone woke me up with alarms.
    I could disable the alarm on the phone each evening after syncing but that would be rather annoying.
    I want to set the same wake up alarm time on the 5S for every weekday morning and still be able to sync with the phone without the phone interfering with the alarms set on the 5S in any way possible. How do I do that?
    Or should I just disable garmin mobile app permission to acces the phones clock app?
