Alarms
Alarms set up directly on the watch are being overriden when syncing with the phone with alarms sets on the phone via garmin connect.
This means if you add an alarm through the watch, when the watch connects to garmin connect it will delete that alarm. Same thing if you try to edit an alarm.
I wonder if garmin can fix this. It was a good thing being able to set the alarm via the watch only, like on the old fenix 3.
Anyone knows if this is a bug or a feature and thus "working as intended" (but then, if so, why give the possibility to setup alarm through the watch if they are overridden and thus completely useless?)
