Improvement wishlist
Here is my list of desired improvements/updates.
1. When using autoclimb, have the option or default to return to the data screen that you were at prior to auto climb instead of returning to a default screen.
2. While following or doing course, increase the line width of the track you are following and increase the size of the position triangle. I had the F3 which had thicker lines. F3 was easy to follow or see track, I struggle much more with the F5X
3. For TBT directions, I get two prompts, one very close to the turn, the second after the turn was already made. I imagine that one should be an early warning and the second a reminder. In reality the second one happens after the turn was made, each and every time. Is there a way to fix this?
4. I have the Varia vision and I only get the second warning (which is after the turn was made) can this be fixed.
5. On the Varia Vision I an ubable to display elevation fields, like grade and total elevation. Can this be added?
