Yes, and the update was ok. No issues in the process.
Thank you. Glad to know that :) You have installed the beta firmware on your fenix 5 APAC or 5S APAC?
See this post, you do not need to install the beta version. It will upgrade you to production 5.10 :
https://forums.garmin.com/forum/on-the-trail/wrist-worn/fenix-5-5s/1238381-what-s-going-on-with-firmware-versions?p=1240532#post1240532
https://forums.garmin.com/forum/on-t...32#post1240532
Follow this procedure, its simply [h=2]Installation Instructions[/h]
- Download and unzip fenix_***Beta.zip
- Place the gupdate.gcd file, found in the System_v*** folder, into the \GARMIN folder of the device
- Place the gupXXXX.gcd file, found in the Sensor Hub_v*** folder, into the \GARMIN\REMOTESW folder of the device
- Place the gupXXXX.gcd file, found in the GPS_v*** folder, into the \GARMIN\REMOTESW folder of the device
- Place all files found in the Text_v*** folder into the \Garmin\TEXT folder of the device
- Disconnect from your computer and proceed through the update.
- If you would like to revert to the last public release software, drop the gupdate.gcd file found in the System_Backdate_v410 folder in the \GARMIN directory
- NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
