Maps and Training Plan
Hi, I planned a training session during a business trip, and I'd like to follow a route I've created on Garmin Connect, and in the mean time track my training session with its steps. Does anybody know if its feasible ? Thank you for your support
  • I tried to copy activity and add custom fields, steps were not possible to select in any menu, so probably it is not possible. On the other hand - why it is important for you once you have the exact distance in meters.There is a relation, each meter is 1.something of step so you can estimate the target distance. Steps are anyway quite an estimated information, in my case steps were increasing while sitting in front of computer, probably I moved hand too much.
    Not sure I understood your question, but just in case.
    First of all check you have correctly uploaded your course: you can go to the app "Navigation" and choose the option "follow route. You should find your route in the list of active courses.
    If the route is there you can exit the app "Navigation" and start your preferred training app (running, walking, hiking or any other).
    Just before starting the app you long press the menu button and scroll the app menu until you find "navigation", select it and scroll until "follow course", select it and scroll active courses until you find your route.
    You will be asked something like "follow this route?" Select "yes" and start your app.
    If your app has already the map screen in the active views you will find the route and the indications over there.
    Hope that helps.
