Walk application has disappeared???
Hello all, just got today my brand new 5x.
I immediately started to set it up : one of the things I did, I moved the walk app from the cloud to the watch (using Garmin Express).
After doing so however, the app has disappeared. It is not visible on the watch and not visible on the cloud.
Where is it? How do I get it back?
Thank you for any suggestions...
    Select the apps list by using top right button on watch.
    Then whilst in list navigate using bottom left button.
    Continue to press it till all the way at the bottom and you should see the whole screen show + Add.
    Select this one with top right button and you will then enter the list of all default apps currently not installed.
    From here you can cycle through and select the walking app.
  • Thank you, this worked on the watch itself. THe app was invisible in Garmin Connect but became visible on the watch. All is good now. THank you!
