Hi,
I was 2 weeks in The Netherlands, a country that is almost always at 0 MSL +-2, so I used this time to understand how to read the barometer field and "predict" changes in climate. I read the manual, and it says that you can select between auto, altitude or barometer depending if you're going to travel and change your altitude or no. Clock will understand that altitude is always the same, and show the changes in atmospheric pressure.
But it didn't work, beeing in the same spot, altitude change from 0 to 12 meters, without moving the clock more than 500 meters. As English is not my language, I changed the configuration and started using barometer, but doesn't matter, altitude keep changing, when clock wasn't moving.
My problem is that atmospheric pressure didn't change, no matter what I use, it always say the same, and when I manually update the altitude, then it changes the pressure, but this is not useful, for that I don't need a clock with barometer inside, just use my phone to check on the internet...
Am I using bad the clock? Am I not understanding the manual? Is my F5X broken?
Thanks!
