Pool Swin, data screen 1 doesnt show up
The fist screen that i set up for a pool swim doesn't show up on the watch during the activity. I had to set it up starting with screen two. So far only see this issue with pool swim. Running 4.1, tried cycling power with no differrnce.
  • Odd. Is the rest screen perhaps causing confusion? When you press Lap to rest, the screen inverts (light text on dark background) and a rest screen appears with time and distance for the last interval, along with two rest timers. Maybe that is what you are seeing? If you don't like the rest screen, you can turn it off in the menu.
  • The fist screen that i set up for a pool swim doesn't show up on the watch during the activity. I had to set it up starting with screen two. So far only see this issue with pool swim. Running 4.1, tried cycling power with no differrnce.
    I ended up deleting the first page in settings (the page that didn't appear in the activity) and the new page one is showing up fine. Just an odd issue that is now fine. Thanks.
