Line Watchface daily resets
The Line Watchface resets daily whats annoying, that the weather api key is also gone.
When will Garmin bring out a stable build that Watchfaces dont reset every day?
Each Watchface i had installed was reseting.
  • You may want to try the 4.16 beta, and be sure to follow the instructs, as there are files you need to put indifferent places. I'm wondering if you're missing one of the "not main FW" bits. You can also try Garmin's "webinstaller" to make sure everything is up to date production FW wise.
    Was working a few days with getting smart notifications now suddenly total crash again reinstall necessary.
    Beta have problem with maps.
    Yesterday or so there was an update, but i still get total crashes where only reinstall helps.
    Newest issue is that Line freeze time then i switch around and time is shown correct, but sunrise sunset is gone. I have to do the gps trick to get it back.
    Hi Guys,
    Ok thanks to the finding from brstreetlaw, I've found a workaround of sorts. It's not a good one though, garmin needs to fix it.
    I had issues where if i set the watch faces up on GE, it works fine for ages, including when i do a wifi sync.
    However, if I had set the watch face up in IOS GC, and then later did a wifi sync (direct to cloud), the watch faces reset.
    The issue is that you can only use ONE of the methods to sync your watch. There are infact three methods, but it's split into two groups, allow me to explain ;
    1) Garmin Express on PC. 2) WIFI (connects direct to cloud). 3) CIQ app on Smartphone (blue tooth).
    Method 1 and 2 are the same ... if you use GE to configure a watch face, it will hold, even if you then use WIFI ... it holds forever ... doesn't reset the watch face.
    But, the moment you use a smartphone to sync, the watchfaces all get reset. You can of course re-do the watch face config from the phone, but if oyu are like me and you use WIFI ... then as soon as you do wifi it gets reset.
    So for me, I am now going to only ever use GE and WIFI ... but it means no smart notifications, and no configuration possible via the Smartphone (IOS-Bluetooth for me).
    Alternatively, you could resort to only using the Smartphone .. and never use WIFI, never use GE.
    Garmin need to sort this out.
