Hi,
I think I am going a bit lost with using both my Edge 1000 and Fenix 5X together. My activities are almost all cycling. The Fenix added some really nice additional parameters that I'd like to monitor - training load and training effect. At the beginning I was using both devices to record my cycling activities where the Fenix recorded it as MTB or road cycling. At the end of the ride I delete the Fenix activity from connect and strava since I got two records for the same activity which resulted in double distance and calories. As a result I would loose the training effect values. So for the next rides I would activate the Fenix as indoor cycling - at the end of the activity I would edit the Fenix activity in connect and change the calories to 5. The distance was zero, but I would get the training effect parameters stored. The problem is that now my training load values are much lower than they used to be.... So - I am very confused. Is there a way to get the two working together? At the moment the only solution I see is to delete the Edge activity from connect - but I don't really want that because I use some IQ calculations from the edge... as well as other sensors which are connected to the edge...
Thanks,
Itay
