I was trying to figure why Garmin calculation of RHR was so different to the manual one I was taking at the beginning of each day..... then I found this!
"RHR: This value is for the current day. It is calculated one of two ways. For users that wear their device while sleeping, the device will read and record the average of all readings while they sleep, excluding periods where any steps were detected or the measured heart rate fall outside reasonable bounds. A minimum of four hours of sleep time is required to register a reading. For users that do not wear their device overnight, RHR is determined as the lowest average reading over a one minute time period during the day."
I really don't understand the logic of taking an average of you heart rate throughout the night (12am - getting up). Your heart rate is always higher at the beginning of the night as the liver and kidney's filter out toxins and stress hormones fall to a normal level. For me, it's normally 3:30-4:00am when the heart rate levels out and remains at a steady level until I get up. The time you would normally take a manual reading. I haven't found anything online that would suggest taking an average of your heart rate while sleeping.
This issues has also been discussed on the forerunner 235 forum
What it means is the data collected isn't as useful as it could be. it always seems to be about 4-5bpm out on average. This wouldn't be a problem if you could manually override the figure with the heart rate immediately after waking, or even have it as a menu option to enter manually or take reading X amount of minutes before first getting up. There is also the issue of increase heart rate during REM that is perfectly normal but could also affect your RHR.
Interestingly though, one option (if you want to record sleep data) is to sync the watch when you wake up and then restart the watch. This clears the data and forces it to record the lowest heart rate for that day.... which is far more accurate that then nighttime average (form me). There are a number of times during the day when my heart rate falls below the current RHR calculation but is completely ignored.
Anyone else noticed this?
