Map Overlay Custom Maps issue
hi,
i´ve copied a custom map to the fenix 5x. its a .kmz file. on the watch i can navigate to map config. where every map could be disabled or enabled.
if i try to disable my custom map to use another map and switch back to the map application or navigate app the custom maps is still there as an overlay. when i look back into the map settings the custom map is enabled again?? the only way to use the stock maps again without overlay is to delete the garmin custom map.
the custom map was created with "kompass digital map" garmin export.
any idea?
thx
