Does the watch use the GPS to decide where you are and then display weather data for that location? I assume it's getting weather data thru the Connect app, but the only place I see to enter a location is in the Profile and Privacy section of the app-I don't see a section for the Weather. If it does use the GPS for location, I assume that the widget adjust the weather data as you change location?
Thanks. Now I'm wondering what service it uses to draw its data from, as it seems accurate here at home but is several degrees off from the local tempa couple of hours away in the mountains.
