Fenix5 x and Polar H10
Hello to all.
New chest strap Polar H10, will work with fenix5 x ?
Thanks!
  • Well the manual says the Fenix 5 range is compatible with BT HR monitors.
    But if you have not bought it yet you may want to look at an ANT+ HRM.
    Thanks for your answer.Actually i have a garmin hrm-run (4) but it seems that i cannot use it anymore.It died a few days back ago.After almost 2 years, i've changed the battery but after that it worked until few days back ago.The watch does not see it at all.I've put another battery and it's the same think.Watch will only find my scosche rythm+. So i am thinking to buy a new chest strap and i am not decided yet which one to buy.
    Wahoo tickr x , Garmin HRM-RUN(4), Garmin HRM-Tri, Polar 10.
    Thanks!
  • I Have a Polar 7 and it will find it, connect to it but will not receive HR data. When I check the watch data screen the monitor connects and after 2 seconds disconnects. This sequence repeats and no data is recorded. Hoping this can be resolved.
    I bought the H10 and used it once during a run and it worked as expected. However, I attempted to use the H10 several days later on another run but it would not connect to my watch. I tried several times with several approaches with no success. Could have been the unit was bad or could be software related. Either way I returned it and bought the Garmin HRM4 and have had zero issues.
  • Thanks for your answer.Actually i have a garmin hrm-run (4) but it seems that i cannot use it anymore.It died a few days back ago.After almost 2 years, i've changed the battery but after that it worked until few days back ago.The watch does not see it at all.I've put another battery and it's the same think.Watch will only find my scosche rythm+. So i am thinking to buy a new chest strap and i am not decided yet which one to buy.
    Thanks!
    One vote for the Tickr X here. I have one, and have started using it rather than the HRM-Run. It doesn't give all the run dynamics, but it's reliable.
