how to set correctly warning before storm?
In default there is 4 mb / 3h but before last storm there is no warning, should i set it in different value?
  • In default there is 4 mb / 3h but before last storm there is no warning, should i set it in different value?
    I would like to know same settings. Today I went from home to my friend, while visiting there was big storm, didn't saw anny changes in my watch in barometric view due to big storm :/
    After looking into it I'd like to come up with some guesses. The short of it is, change the setting to the lowest possible rate. That is, if you're using millibars, change the rate to 2mb/3h, hectopascals 2hPa/3h, etc.
    Lately I have been interested in barometric pressure and weather but I still think predicting weather based on pressure was something more commonly done in the 1800's like on a farm or at sea.
    Take a look at these old things.
    https://encrypted.google.com/search?q=barometer+weather&safe=active&hl=en&tbm=isch
    http://www.artofmanliness.com/2015/07/07/fair-or-foul-how-to-use-a-barometer/
    https://en.wikipedia.org/wiki/Atmospheric_pressure
    Pressure is measured a few ways: bars/millibars, pounds per square inch (psi), pascal, atmosphere (atm), and a few others. It doesn't really matter which one you use. They're all units of measurement.
    Now, air pressure varies all over the Earth. Some places can see dramatic swings in air pressure while others may not and weather relies on a bunch of other junk (humidity, wind, temp., altitude, etc.) With that being said, I don't think meteorologists today solely rely on a barometer or if grandpa's trick knee starts aching to know when a storm's a'brewin'.
    Maybe at sea a huge drop in air pressure indicates something big is about to happen or right before a tornado the air does something funny. Where I live, it's on average 60-70% humidity even without a cloud in the sky. I couldn't say what causes the rain to suddenly drop when it wants to.
    For us living in cities, I imagine one reason generations before us picked these specific parts of the planet to dwell was because they didn't experience dramatic weather changes. Consequently, I think of the barometer as simply a toy unless I was climbing Mount Everest or sailing across the ocean in a tiny sailboat. If I'm at home and the pressure swings so dramatically to trigger an alert, the only thing I could imagine is a tornado is about to wipe me out or something.
    ...Back to the settings on the watch...
    Looking at the NOAA http://www.weather.gov/ for the barometric pressure swings during a storm in my area last Friday, the pressure didn't suddenly drop our anything even though it started to pour outside.
    the pressure from hour to hour was like 1001.5 millibars and the next our it was 1002.1 millibars or something. According to the wikipedia article I mentioned above, pressure in millibars is usually rounded so, if anything, in the course of an hour the pressure raised either 1 millibar or not at all depending on the rounding. If the watch setting is at it's default for millibars- a 3 millibar change in a 3 hour timespan- there's no way I'll ever see an alert
    where to change the unit of measurement
    Settings > Sensors and Accessories > Barometer > Pressure
    (it doesn't matter which one you pick. Probably just pick the unit of measurement used in your part of the world)
    where to change the Storm Alert
    Settings > Sensors and Accessories > Barometer > Storm Alert > Rate
    I went ahead and set my threshold to the lowest setting of 2 millibars / 3 h to increase the sensitivity to be as sensitive as the watch makes available.
    Ok thx for info, settings change
    Now we have to wait for storm to test if it works ;)
  • After looking into it I'd like to come up with some guesses. The short of it is, change the setting to the lowest possible rate. That is, if you're using millibars, change the rate to 2mb/3h, hectopascals 2hPa/3h, etc.
    Thank you for long explanation. I'll try settings as you said and wait and observe for storm :)
    thanks again
    I just changed mine and had it give me a storm alert while in the bathroom lol. I may leave it on the default settings. I'd like to imagine this storm alert setting is really meant for a serious outdoors activity like climbing or maritime stuff. I don't think you'd find it meaningful if you're chilling at your desk because air pressure is goofy. If you were on the side of a mountain and the air pressure dropped suddenly- yeah- that could indicate some serious stuff is about to happen.
    Sensors on a watch or smartphone (most smartphones have barometer sensors) aren't really as cool as advertised because they are probably meant to sit in one spot and take a measurement.
    If your watch is a single data point and it's constantly moving around, you're probably not going to glean beneficial information. Some apps will crowdsource a bunch of people's sensor readings and then that might be useful. Imagine if millions of people used this app and the data was averaged across a city of users:
    Say, with this app https://play.google.com/store/apps/details?id=com.opensignal.weathersignal
    ...but if it's one watch or phone, it probably won't be useful unless you're hanging off of a cliff and the weather does something drastic.
    You could maybe glue a watch or smartphone outdoors on a post and compare it's temp/altitude/pressure/humidity/magnetometer/gyro/accelerometer readings to itself over time and get some ideas of weather events or earthquakes but sitting on your wrist or in your pocket isn't really an ideal weather station.
  • Changed mine to 2mb/4h Yesterday. Just got an Storm Warning. No storm, but probably will rain today.
    Will keep an eye on it, and raise the mb if needed.
  • Do you still have your watch? What watch did you have what do you have now? How did your settings or barometric pressure/storm warnings work out for you? Thank you
  • There are two major types of thuderstorms. A) occures when it's warm and there is a lot of humidity. That humidity rises which cools down the air. This leads to a huge difference in tenperature within a cloud. That difference causes what we call heat thunderstorm
    B) when a cold front comes in, this leads also to a rising of warm and humid air bc the cold front slides under the warm air.
    For type A) the pressure alarm is useless. For type B) your watch should alarm you.
  • I get a storm alert any time I use an elevator over about 10 floors, any time I go diving (it’s a Decent) and most times I get sweaty. Ah well. It was cool in theory.
