Hello,
I've had my Fenix 5 for 3 weeks. Fw 2.72 (and now 2.9) seem to have fixed the freezing/losing satellites i've experienced early on (so i kept the watch past its return date).
However, i'm having the following issue now: I have several run activities where the total distance differs by 1k (on a 15k run) between the watch and strava or mygpsfiles.com...
Not sure which one is correct: i've taken my forerunner 225 along on some of the runs and it matches the fenix 5 (and there's virtually no difference between forerunner 225 and its strava activity)
It seems to only happen in the city, where around buildings, where the track is very 'wobbly' (as expected). On the trails, the fenix 5 seem to be happy (and matches strava distance)
My assumption at this stage is that the watch does something smart in calculating the distance, but using the 1s recording, it still records all the GPS 'errors' in the fit file, leading to strava getting 1km more on the total distance (screwing up all my paces, segments, ...)
On the forerunner 225, since the track is only recorded using 'smart' recording, it looks smoother, and distance is calculated pretty much the same as GC in strava.
If i export the fenix5 GPX (only GPS position info) in garmin connect, and re-import it, the total distance is the one reported in strava or mygpsfiles
ex:
Trail run 9.64 km in GC shows up as 9,6km in strava (great)
City run 15.36 km in GC shows up as 16,2km in strava
City run 14.77 km in GC shows up as 15.9km in strava
today with both watches:
Fenix 5: (fw 2.9, GPS+Glonass, 1s recording)
Garmin connect: 14.37 km
Strava: 15.2 km
Export/Import as GPX in connect: 15.22 km
Forerunner 225:
Garmin connect 13.95 km
Strava 14,1km
Export/Import as GPX in connect: 14.15 km
(i can live with 200m difference...)
My next step is to try again, with smart recording
Should i disable Glonass as well?
i've raised it with garmin support but havent heard back from them yet...
Thanks
