Snooze for alarm
Just noticed the option to snooze alarms. Anyone know how long the default is and whether there's a way to toggle that?
Separately, has anyone had issues with alarms not staying 'on'? I've had this happen a couple of times now (alarms turning 'off' without my intervention) - never happened with F3/HR
    The default I believe is 10 minutes. I use it everyday and never had it fail. I did however it have it fail on my F3HR, but since switching to the 5 never had it fail.
    Not sure where to change the value never thought of changing it
  • Snooze is 10 minutes.
    As far as the alarms resetting, make sure you set the alarms on Garmin Connect Mobile to match your watch for now, as what's probably happening is they get reset when you sync, as GCM doesn't know you have an alarm set, so it's cleared.
  • Hi,
    The default is 10min - i did not find where to change this value.
    With the Alarms you have to be carefull. Settings you are doing on the watch are always (daily?) replaced by the web-sites settings.
