(And why do they put red on it anyway? You can customize the color of the strap and the watchface but hey here's some red bits to clash with it).
I had the same problem twice already (Livetrack staying on and cannot be disabled). First time I did a factory reset, which is tedious as you have to setup everything again. The second time I deactivated LiveTrack autostart from the GC app and tried to manually start a Livetrack session through the app afterwards. This failed the first time, but the watch didn't think it was stuck in a Livetrack session any more and worked as expected.
Thank you for the info!
Garmin told me to do the factory reset too, which I've done.
It's not just the tedium of setting everything up again, but I guess we also lose personal records, training metrics etc that apparently take weeks to build up.
I had a feeling the same thing would happen again if I try LiveTrack, so it's good to hear you found a workaround. Maybe I can avoid the reset next time.
