No strava segments on F5X
Background:
1. Strava premium account - YES
2. Starred segments in Strava - YES
3. Connection between Garmin and Strava - YES
Still no segments on the watch. Will they appear during the run or something is not working?
Beside of that I am a bit worried to try to fix the problem once few had problem with the watch when Strava segments were syncronized.
Any ideas?
BR,
Wojciech
  • If you go to garmin connect at https://connect.garmin.com/modern/ and click on segments on the menu, do you see Garmin segments or the message, "You are using Live Segments." below the Strava header?
    First thing to check is that you have actually switched to Strava segments in garmin connect. This can be controlled from the gear wheel of the segments widgit within garmin connect on the web.
    Next would be to check if the segment fit files have been downloaded to the watch itself.
