What's the best way to get Garmin's attention/reaction for this issues? Just wondering, if this can/will be fixed in the future.
The best way is that all with such issues to complain here then call garmin and direct them to read this thread. If there is a hardware thing than at least they should acknowledge as there is nothing to be done.
So, I can also now confirm, that similarly to "Dutch30114" experience, the annoying disconnects are now gone after downgrading from 2.72 back to 2.40.
To clarify - the "disconnected/connected" issue was present for me on 2.40 as well, from day 1. So, what was done chronologically:
- Got the watch, registered/set up in Garmin connect/Express
- Paired with the phone (sony Z1 compact, Android) via Garmin connect Android app - worked with the 3rd attempt
- Updated to 2.40 firmware
- Happy for the next day :)
- Realized that watch drops the connection with phone every 20 min or so, even within half meter distance from each other
- Noticed the 2.72 Beta - so upgraded by following instructions
- Still same issues on 2.72
- Downgraded back to 2.40 (WILL WIPE YOUR SETTINGS, VO2Max etc!) - as per "Dutch30114" suggestion
- Re-paired with the phone again, put all settings back manually (backlight, alerts etc.)
- No more disconnects every 5 minutes
- Still weak range - 5-10 meters max
- Sometimes the watch still needs "help" to connect back (re-enable bluetooth on the phone)
My theory is that perhaps, for those who also have such disconnect issues, there is no need to upgrade/downgrade, but just reset to default and re-pair.
*Disclaimer - the above are just my experiences :) - I'm not encouraging you to reset etc., entirely up to you!
I spoke to Garmin support today. I got a Fenix 5s about 2 weeks ago and it also always connects/disconnects from my phone. At first I thought it may be my phone (I have a Pixel). Response is if you turn off the smart notifications it will work but it will also turn off phone and text notifications. It is all or nothing, so you basically have to accept it :mad: wrong answer. This thing was too expensive to not be able to turn off the annoying stuff and leaving the important stuff. Maybe with enough complaints they will realize something needs to be fixed.
