Hi Guys.
Those that have the F5, can you check the following.
I have a F3 and when I choose Mountain biking, it doesn't uplaod into Garmin Connect as Mountain Biking, instead it's cycling and I have to manually change it.
Is this the same with the F5.
Also I do a lot of trial running latley, I went to use Navigation > Activities > Select the previous trial run I did > Go > Select Trail Run. But there is no "Virtual Partner" which I find handy to see if I'm faster or slower for any given time.
Seems only available if I select "Run"
Is this also the same for the F5?
Cheers
