I used Forerunner 235 before and Fenix 5 now, both of them always have the same problem with sleep tracking. When I didn't wear the watch, the watch is still tracking like I was sleeping @@.
It happened for a long time and I wonder why Garmin doesn't fix it asap.
Anyone else is facing this?
Any temp solution for this issue? Many thanks!
I used Forerunner 235 before and Fenix 5 now, both of them always have the same problem with sleep tracking. When I didn't wear the watch, the watch is still tracking like I was sleeping @@. It happened for a long time and I wonder why Garmin doesn't fix it asap. It has been causing the sleep statistics are not accurate at all. Anyone else is facing this? Any temp solution for this issue? Many thanks!
Tracking sleep is actually done server-side by the Garmin Connect service, based on movement data downloaded from the watch. Garmin Connect has no way of deciding wether lack of movement is due to sleep or due to not wearing the watch. And to add even more complexity - you could be sleeping while not wearing the watch :)
The only way to fix it would be to add optical HR data into the equation for verifying if the watch is worn or not, but assuming that OHR is not super-reliable, i.e. it sometimes shows pulse even though the watch is not worn, and some people might choose to disable OHR on purpose, I would not expect it to be fixed in any way.
Yes.
A solution would be to manually edit sleep times in Garmin Connect, but I wouldn't call this solution temporary, as I don't expect it to be fixed.
You could also try - if you haven't done it so far - to set up your regular sleeping hours in Garmin Connect.
