What do you set for GPS ?
Hi there,
Under Settings > Activities & Apps > Run > Run Settings > GPS
The 3 options available are:
- Normal (GPS Only)
- GPS + Glonass
- UltraTrac
what did you all set to ?
Thanks
  • I would definitely use ultratrac as it gives the longest battery life by far.
  • Depends on what you use it for...
    If you want a accurate track recording, I would use gps set to 1 second. gps+glonass gets no better sat signal, it only gets a more stable sat signal under difficult conditions (and consumes about 20% more battery).
    Thanks but I do have have the 1 second option.
    I only have 3 options under Settings > Activities & Apps > Run > Run Settings > GPS and they are:
    - Normal (GPS Only)
    - GPS + Glonass
    - UltraTrac
    Are you referring to Normal (GPS Only) ? Thanks
    No wonder, I set to "GPS + Glonass" and the battery really runs out fast ...
    Thanks
  • Spend a little time looking at the manual and working through the device menus before peppering the forum with questions. See Page 23!
