So it begins.
I will have mine Fenix 5 on Saturday and will start doing comparisons to an Ambit 3 Peak. I don't have an F3 to directly compare to as of now.
Anyone have an F3 and F5 to compare?
Does the new beta contain a GPS firmware update?
I did not see anything mentioned in the change log
What is the version you see in the watch for the GPS module?
Current one is 4.30
Don't forget that map distances aren't necessarily 100% accurate either. For roads, your running route will follow the curve of the kerb at turns, where the mapping shows a straight line extending out to connect with the straight line of the cross road; trails tend to be windier than the map data properly represent. They're not big differences, but they are the sort of thing which are only truly accurately measured by the sort of techniques that course measurers use.
FWIW, I found that my Ambit 2 typically came out about 1% short compared with gmaps' measurement of the same route, and that's one of the devices generally held up as very accurate.
Not sure if anyone's posted fellrnr's purchasing flow chart, which didn't make exactly the recommendations I'd have expected from him:
https://twitter.com/fellrnr/status/858775723405869056
Wow, he loves his stryd...
