Coming from the original Fenix which had a base map (and the ability to have custom maps), the mapless F3 was a bit of a step back. Later I've bought an Epix to have maps, for hikes and trail runs only, at least that was the idea. But I'm using the Epix every day, because it's so convenient to always have maps without having to take out a phone. The Fenix 3 was starting to gather dust and my other half is now using it. So if you ask me, maps are worth it, unless you don't mind using your phone or a handheld GPS (bigger screen, easier to use).
Actually since Garmin fixed the screen lock on the Epix (before the fix, you could not use it in the rain, the touchscreen would go nuts), I doubt if I'll get the 5X, because the Epix works great (but in case you are tempted to buy an Epix -not so expensive these days- make sure to head over to the Epix forum to read all about the bugs that it still has, and the functionality that it doens't have compared to the Fenix 5X).
Is it comfortable to use mapping functions of Epix with keys, not touchscreen?
Fenix 5x has much more RAM then other F models, so it will have more than 1 MB RAM for CIQ apps compared to 128KB with 5/5s versions. It was the same with Epix too, as it has 32 MB RAM chip; why not to utilise it.
CPU may be the same or some cheaper one but running at higher frequency like Epix vs. F3. We'll see when it's released.
Sis651, could you tell me where you got the the data re the CIQ memory differences from? Or could you detail a little bit on that? I mean I do not need the map function of 5X but I wonder what I might loose in the future if I go with 5 re internal CIQ memory etc...
Thanks,
Meste
^^^^ looks like a typo in the watch_app memory_limit variable for the 5X (10 times larger ?) so maybe we can't fully believe those numbers ?
