Today I did a park run and spent 60% of time in zone 5 yet my anaerobic training effect was 0.9? Surely that isnt possible? The rest was in zone 4. My aerobic was 3.5
Unless the rapid elevation of HR is counted, too. Alas, I did not make intervals with my F5+, which I still have, but made my first HIIT with my F6X, and it seemed to me at first glance that not just speed counted, but also my HR, more exactly the change of HR. The terrain was mixed, some sprints happened on flat, some on modest climbs.
Wind is not considered by watches, of course, although my Stryd does. Maybe sometime in the future when a power based running workout will be launched by Garmin then the effect of wind will be implicitly incorporated.
Thanks for info. I understand how intervals may show more anaerobic effect however other 5k or even a 10k race showed anaerobic effects of 3 or 4 a few months ago and my times are only a little faster 5-10 seconds with no improvement in vo2max so assume I'm not fitter. Just inconsistent but as you say it's just algorithm and probably not very accurate
Maybe not inconsistent, just not fully transparent and too complicated to “reverse engineer” it.
A guidance fyka www.firstbeatanalytics.com/.../
VO2max will not continue to increase past a certain point. That's a physiological limitation and nothing to do with any algorithm. However, the algorithm is likely to also reflect that physiological limitation. Once your VO2max plateaus either measured or estimated by algorithms, fitness gains are indicated by increased speed for the same VO2max - that's your indication of improvement. Better to focus on speed increases over events than VO2max after a training session.
