Fenix 5x+ v. 16.71
I was just a crawl.
GPS track caught an anomaly .. I changed the calculated km manually to 10200m but it was below 9000m
Fenix 5x+ v. 16.71
I was just a crawl.
It is not unusual that you get these anomalies - remember your arm is just above water for a second, so mostly et requires at very good signal before you jump into the water.
I myself (Fenix 5+) does not use the beta version, and do rarely have the problem and my route is usually "prettier" to look at than yours. Yours just might be because that you have not zoomed enough into to route.
If this happens very often I would then try to downgrade to the 15.40 firmware.(notice that the firmware you are currently running has been a beta firmware for a VERY long time.
