Where can I see my bodytemperature? This is an outdoor watch and i need to see it to avoid hypotermia.
Hypothermia results from the body's core (inner) temperature cooling below a critical level. https://www.medicinenet…
Instead of depending on a watch to avoid hypothermia, you can look for symptoms that don't require a watch like 99.9% of…
This product claims to measure body temperature and has ANT+ and Bluetooth, so it should work with the Fenix 5 Plus: www.cosinuss.com/.../
Instead of depending on a watch to avoid hypothermia, you can look for symptoms that don't require a watch like 99.9% of the population. Here's a few and you can find more online.
Recording skin temperature presents extensive difficulties. Although it is not a clear indicator of internal body temperature, skin temperature is significant in assessing the healthy function of skin.[2
The F5plus series is not advertised to display body temperature. No Garmin wearable is measuring body temperature out of the box, so far. At first it can't, but maybe this data field will help you:
Estimated Body Temperature Data Field | Garmin Connect IQ
In the IQ store, there is also a widget from a different developer available
But I can´t say, which of these 2 above mentioned is most accurate / close to the real value.
Or you have to buy this (€ 230): Device for continuous and accurate core body temperature monitoring - CORE
Hypothermia results from the body's core (inner) temperature cooling below a critical level. https://www.medicinenet.com/hypothermia_extended_exposure_to_cold/article.htm
Measuring skin temperature is of little use.
The best way to avoid hypothermia is to wear clothing suitable for the conditions.
