I got brand new garmin fenix 5 plus from amazon. It was fully discharged.
1. is the battery safe to use? is it stable?
2. i charged it as amazon asked me to, but the percentage went from 38% to 61% in 2 hours AFTER I UNPLUGED IT.
Lithium batteries get broken when they are discharged for a longer period. The question is how long your watch was discharged. Mine was discharged too, but works for now 18 months with a good battery life. So I didn't have a reason to return it.
If your watch showed that loss because you tried things out, adjusted the settings etc., then it's probably o.k.. If you didn't use it (and you didn't install 3rd party apps), then it's not.
I've had the occasional watch fully discharged on receipt. Never worried about it and never had any problems with battery life. I rarely fully discharge my watch but always fully charge to 100%. I believe battery technology has moved on considerably since the days of 'battery memory' and any need to worry about charge/discharge cycles. But I'm not an expert and I know full well that some people believe otherwise.
In your case it might just be the battery indicator. See how the charging indication responds after some full recharges and then some usage. If you are unhappy arrange a replacement with Amazon.
My watch was empty, when I bought it.
Charge it with a high capacity charger and not on a computer, wait 1h longer until it shows 100%. Then switch the watch off, wait 20s and switch it on again. When I do that in the evening with everything switched off (Bluetooth, optical heart rate), it has 98% in the morning.
I got a 5x Plus Sapphire the other day from BestBuy because they where on sale for $399.00. The battery was completely discharged and it had a problem with the backlight not working all the time when I raised my wrist, so I exchanged it yesterday for another one. This one was completely discharged too but the backlight worked fine on this one. Once the battery got to 20% I disconnected it so I could install the new maps and firmware, and when I plugged it back in after that it said the battery was over 30%. I have been using it and did a couple walks with it so far and everything seems normal.
I would not worry about it unless you start having problems.
It's not good for a lithium ion battery to be completely discharged (article). But there has to be a protection circuit in the watch that avoids complete discharge (and prevents damage to the cells). Nevertheless, if it was discharged for a very long time a battery can eventually fail and won't charge anymore.
If the unit still takes a charge and holds it, and has gone through a number of charge/discharge cycles normally, I wouldn't worry too much.
There is no way to know if "0%" or "100%" as displayed on the watch are absolute numbers of if they include safety margins.
Thank you for your answer
