Total elevation 0m
I just bought the garmin fenix 5 plus and tested it out and went on a trail run. Whene i came home i saw that the total elevation was 0m i went in to details and saw that the graph of elevation was well drawn and even had the highest and lowest elevation totaly accurete(420m and 1950m) is there a setting that i have accadantly turned off or is my watch broken?
  • No idea what you might have accidentally done. Have you checked the manual for the settings you might need?
  • If you want support, you should give more information. Where do you see 0, on the watch or in Garmin Connect? Do the widgets for barometer and altimeter work? Did you use the regular Trail Running App or did you install a 3rd party app? etc.
    Apart from the manual, you can find additional information here:
    support.garmin.com/.../
    0 Former Member over 4 years ago
    I used the garmin trail running app i see 0m on my watch and in garmin connect. And in my compas widget my altimeter in the last 4 houers dosnt show any data and i have my altimeter turnd on in the settings. And the same is with the barometer....but it is weard that the grapf for altitude on garmin connect on the computer is drawn and it is corect...idk what is wrong
    +1 Former Member over 4 years ago
  • Garmin Connect can correct the profile with map data, this is mostly for watches without barometer, because GPS based height measurements are not very precise.
    If the barometer doesn't show data, the watch is probably defective and you should send it back.
