Triathlon pool size
Hi all
If you do a Triathlon activity there are two options for the swim leg: Open Water and Pool Swim.
What is the pool length that the Triathlon activity uses? Will it be the same as a Pool Swim activity? It doesn't have the option to set the pool length within the Triathlon activity.
What do you think?
Cheers
Vassilis
    0 Former Member over 5 years ago
    I tried it once, and the pool size was indeed 25 meters, same as I had used before in the Pool Swim app. But 25 meters is a default setting, so it does not prove much. However, it would be logical that the Triathlon activity is a list of 'pointers' to regular activities (apps), and the activity/app-specific settings will be the same as when using each of these activities/apps on their own.
    0 Former Member over 5 years ago in reply to Former Member
    Thanks Twinaxx. I will give it a try and hopefully it will work.
