Hi,
Has anyone found anything about the ANT / BLE / BT: 6.03 driver?
Didn't find any information anywhere?
So far everything is going well ...
I had to try the driver from the beta package ...
Stay awake,
Sören
Hi,
Stay awake,
Sören
Hi, and you have no problem if you connect a Bluetooth headset to your watch, for example during an activity, that when it is disconnected, you will have a battery consumption of over 1% in 1 hour! I have a feeling this is the problem with this driver! At least I noticed this on my watch, then only a restart will help so that the watch has back consumption of about 0.3% -0.4% in 1 hour.
Yes, I also have this problem and am waiting for an update because a downgrade does not work
super it is already possible to downgrade the driver from 6.03 to v 5.04 from the sw11.74 file
Tested today and it works as it should again. After activity even with headphones, after disconnecting the headphones from Fenix 5x plus, the battery consumption returns to 0.5% per hour. Everything is normal again, great !!!
