I can listen to music via my watch without problems unless I try to do it running. Then the connection gets lost for a second and comes back again continuously.
Very annoying. Anyone got a tip?
I don't have the Airpods, but I think it might be possible to change if the master (the one that is connected directly to the watch) is the left or the right one. If it is so, try to make the one you wear on the same side of your watch the master: I think that the fact that this happens to you when you are running is because you move your arms away from your head, and putting a larger mass of your body between the watch and the headphones when you run
I can only speak for AirPods as they are the only ones I have used and they have always worked fine. Not sure the idea of a ‘master’ applies to AirPods but happy to be corrected. I know there have been other posts about some wireless headphones that do have a master. Check some of the other threads where they are discussing different wireless headphones. While it is possible to be watch specific, headphones issues could be applicable across all watches.
