2 huge issues with treadmill calibration.
1 - Calibration is off by about 2x on treadmill. I run consistently outside and inside, and inside on the treadmill I’ve had to “Calibrate and Save” 20+ times usually on runs that are 3+ miles. Nothing seems to affect the calibration. It’s always off. I’ve tried resetting several times and no luck. Outside calibration is accurate but treadmill is way off.
2 - Calibrate and Save feature itself is messed up. See the picture attached. When I try to calibrate, the watch won’t let me calibrate to between .00 and .30 of a mile. I ran a 5k on the treadmill (and watch said I ran 6.54 miles, which was off by a bit more than 2x), and when I went to calibrate and save, I could only select 3.30-3.99 miles, not 3.12 for a 5k.
Whats the fix?
