BIKE + HIKE + BIKE all in one activity possible?
Is it possible to combine different activities into one?
E.g. when you  spend a day in the mountains where you first use your mountainbike, then hike and afterwards again use the mountainbike.
Ofcourse i can start a seperate activity for each part, but that's not what i want.
I wanna keep track of the entire day in one activity.
I guess that's not possible with the Fenix?!
  • Yes.. . Just make your own duathlon..... Or Triathlon....
    In "add activity" ... . then choose "Multisport" .... then choose Triathlon"..or "duathlon" ... then add "bike"  "hike" etc. ..
    Hope this helps.
    0 Former Member over 6 years ago in reply to Sam201176
    Yeah, that sounds great!
    Now i just need to figure out how to switch between the disciplines during the activity.
    0 Former Member over 6 years ago in reply to Former Member
    Ok, so with the "BACK-LAP" button you can switch between activities.
    When i'm right, i can toggle as often as i like between the activities and they get accumulated, right?
  • Sorry I'm not sure......I've never tried it.
    You'll have to try it out, and let me know. : - )
  • You can either create a new activity with the sports pre set that you want to use. With the back-lap button you go to next sport in your activity. But pressing the lap button can't be undone. So if you make a mistake you can't undo this.
    Another option is to change the sport type in the original activity. I do that sometimes when i Run and want to do body weight exercises and run back home. I just start the run activity and when i hold the back lap button (for 3-5 seconds) I can change the activity to workout and after the workout i can do the same and select run again. The watch wil later change the run activity into multi sport. But you'll have to try and see what you prefer.
    0 Former Member over 6 years ago in reply to xray79
    The first option is really a show stopper.
    The second option would be great but does not work with the back button on my fenix 5+?
  • Didn’t work for me either, but then I found out I had to select a Hold Button for ‘Change Sport’. By default I think long press back/lap button during activity takes you to the widgets.
    Settings -> System -> Hold buttons.
    Now it works like a charm Slight smile
    0 Former Member over 6 years ago in reply to SAHO
    Thank you very much - with the changed button function it‘s perfect!
  • I definitely recommend using the change sport option.
    When I do indoor cardio I use 3 different machines and usually have a set sequence, sometimes I like to vary my routine and using the change activity button means I can start my first activity and then when I switch to the next I just use the change activity button and select the next.
    I did try setting up a custom activity with the 3 disciplines but it would does not give you the flexibility in the sequence or number of times you do each activity.
  • The second option is perfect for the op....
    I just tested it after selecting "change sport"as a "hotkey"....... I can change back and forth many times...... and after uploading to connect... I can see all my activity markers..and GPS traces.
    I'm keeping the setting now.... I think it could come in handy for me as well.. . Thankyou.
