Fenix 5x plus cihazım wifi ağlarının hiçbirine bağlanmıyor. 0700 hata kodu nedir. Yardımcı olun lütfen. Bu cihazı wifi özelliği var diye satın aldım yoksa dolandırıldım mı garmin.
"My Fenix 5x plus does not connect to any of the wifi networks. What is the error code 0700. Help me, please. I bought this device because it has wifi or I've been ripped off."
First thing to do is to verify that connection information stored on the watch is correct. The SSID which identifies the network must be correct. In some cases, this is case-sensitive - so be sure to match the case which is broadcast by the network. If the network is secured, the "password" must also be correct. The password is always case-sensitive.
If the information is correct, the next thing to do is try forcing the watch to connect to that specific network.
If that still fails, remove the network from the watch, add it back, and try forcing a connection again.
Edited to add: Two other things. First, I don't believe that the F5X+ supports 5Ghz WiFi. If you have control of the WiFi network, be sure you enable 2.4Ghz even if you have no other devices that use it. Second, you can try setting up the WiFi via Garmin Express. I have never understood what's different about this approach vs. setting it up directly on the device. But it might be worth a shot.
That's all I've got. Perhaps someone else will chime in with additional suggestions. If not, and if it continues to fail, a call to tech support is probably in order.
