Not sure if anyone is aware of this, but amazon music is now live in the connect store finally
https://apps.garmin.com/en-US/apps/c6827fc2-5179-4df5-a0ff-3022db30e5ff
Brilliant addition :D
I have the same problem.
Only Amazon is selectable as music provider. I have no access to audiobooks/music stored on the fenix!
Uninstall of amazon music is not possible. I get an error in ConnectMobile when uninstalling the app.
How is it possible to hear music stored on the device now?
long press button and select music provider to your music
Hi, which Button in which screen?
In music settings I can only select Amazon as provider. "Local music/files" can't be selected.
In music screen amazon icon is shows (where only the folder for local mp3 was shown). I can not select another provider. The play button only starts amazon music. Selection of genres etc. for local files is not possible.
hm. strange. I can select between My music and Amazon music.... did you have local music on your device before installing Amazon? if not, maybe thats the reason you can't select.
update: i just tried to uninstall it, no problem. but I select "MY music" as provider FIRST and then uninstalles it.
As music provider only amazon is listed. That's the only entry in the list. "My music" is not listed.
I had mp3s in folder "Audiobooks". I'll check if the mp3s are still present (but I can't see why not). The "My music" entry should be there with or without files.
Update:
-restarted the fenix several times
-mp3 files are still present in folders Audiobook and Music
-music provider selection still only offers Amazon, not "My music"
Update 2:
@Viennaboy: now I know what button long press you meant :-)
Well, now I could select My music and I'm able to hear local music again.
Perhaps this info helps other user to find the right settings menu.
Try this
For those of you struggling to uninstall it - the fix seems to be Start Music Hold down the MENU key to get to providers. My Music won't work, go to Control Phone (it may ask you to start Music on your phone, if so do so and start playback and confirm the watch is showing the file playing) Then go to either Garmin Connect or Connect IQ and then uninstall Amazon Music - that seems to work for me
Thank you for this info.
I can now switch back to the stock player.
My concern here now is - Is the amazon app trying to connect & update in the background, because it is still uninstallable, and consequently draining precious battery life?
Did you try this?
"For those of you struggling to uninstall it - the fix seems to be Start Music Hold down the MENU key to get to providers. My Music won't work, go to Control Phone (it may ask you to start Music on your phone, if so do so and start playback and confirm the watch is showing the file playing) Then go to either Garmin Connect or Connect IQ and then uninstall Amazon Music - that seems to work for me"
