HR Broadcast to Edge series still dropping out.
When in broadcast mode my Fenix 5X plus will connect to both my Edge 520 and Edge 830 as a HRM, however the HR display goes blank at some point during the ride. The connection is not lost, but the data doesn't show. The Edge HR icon indicates a HR connection but the data field is blank.  After disconnecting then reconnecting the Fenix, the HR signal displays again but only lasts for a short time.
I've read through the older posts and it seems to be a common problem but I haven't read of any fix.
Is this still a problem for others?
Software version 7.60 on my Fenix 5X plus.
  • For my understanding, wrist HR is not recommended for cycling. The position on of your arm while cycling will not allow the watch to get a proper HR measure
  • I don't think it's a question of not being recommended as much as it not being reliable and consistent enough when cycling; in fact for 'active' activities in general. I'm willing to bet that the disconnection/reconnection process happens when the OP is stationary hence giving the appearance of a fix. I broadcast my HR from the wrist when cycling indoors generally without any problems but that is likely because I am not moving around as much - at least that is what my butt tells me anyway!
